KOKO self test
Old May 24, 2005 | 02:59 PM
rr66's Avatar
rr66
Default KOKO self test
working on 1990 dodge B-250 Van with a 318 cu in.
have check engine light on. did key-on, key-off (KOKO) 3 times.
got code 3 and then 5 - 5 (or is that 10). think 5 - 5 signifies the end.
so, does anyone know what is code 3 is ??
Old May 24, 2005 | 04:58 PM
moparturd's Avatar
moparturd
Default RE: KOKO self test
You're missing a digit I do believe.
Old May 25, 2005 | 04:37 PM
rr66's Avatar
rr66
thanxs for the reply.
may be a 1 and then a 2 (only thing i could figure), then a 5 and another 5 (is it suppose to end in two 5's (have read somewhere on the net)).
would drive the short distance to autozone - but the inspection sticker is out (costly fine)
the speedometer is messed up. just turning the key to the ON position, causes the speedometer to jump up to 30 - 40 mph. think it goes to 70 - 90 just when it is started
Old May 26, 2005 | 02:49 AM
rr66's Avatar
rr66
saw the codes in the thread by the admin - DodgeGirl19.
Hay, neat.
think all is OK - i hope.
Old May 31, 2005 | 11:56 PM
hicap's Avatar
hicap
5-5 is really code 55. It means all codes were read or all is good. All KOKO tests with older Dodges do this. Normally when you do this test the computer will tell you the first number then pause then give you the other number, pause then it starts on the next code in the same sequence.
