Dakota brake wire harness
Old May 27, 2005 | 11:40 PM
safetech65's Avatar
safetech65
Default Dakota brake wire harness
I have a 2005 Dakota and I need to install an under dash brake controller. The factory supplied harness that plugs in under the dash has the following colored wires.
The Dodge plug has:
Green w Black stripe, Blue w White Stripe, White w Red stripe, Solid Blue (thicker Wire)
I need to connect the brake controller to this harness & the dodge wires are not marked..
Old May 28, 2005 | 11:39 AM
moparturd's Avatar
moparturd
Default RE: Dakota brake wire harness
Might want to check with the Dakota section or General Tech.
