need help with a 91 doge stealth
Old May 29, 2005 | 04:38 AM
randy789's Avatar
randy789
Default need help with a 91 doge stealth
hello i have a 91 dodge stealth that will not run all the time it is wierd some days it will run fine other days it will just shut down and sometimes you have to get out of the car unlock the passenger side door then the car will start again if any one has ever encountered this problem before or has any ideas please let me know
Old May 29, 2005 | 07:36 PM
roachnigga's Avatar
roachnigga
Default RE: need help with a 91 doge stealth
when was the last time you had a FULL tune up...
Old May 30, 2005 | 01:35 AM
randy789's Avatar
randy789
we have done a tune up recently thinking it was a firing problem also we have replaced the fuel pump and the main cpu and the car still has the same problem was wondering if there was something in the anti theft system that would caus e this problem cause sometimes when it is acting up it helps to lock the car go to the passenger side and unlock it then the car will start thanks for your interest
Old May 30, 2005 | 08:21 AM
roachnigga's Avatar
roachnigga
Take ya car to a dyno or dealership and run a FULL dx test. itll pinpoint if your ECU is the prob... good luk
ORIGINAL: randy789
Old Jun 1, 2005 | 10:58 PM
randy789's Avatar
randy789
anyone know if the problem could be the engine control switch and maybe be able to tell me where that is
Old Jun 1, 2005 | 10:59 PM
randy789's Avatar
randy789
or maybe its cause it is a dodge lol lmao
Old Jun 4, 2005 | 06:29 PM
randy789's Avatar
randy789
update we have replaced ecu and still the same problem does anyone know anything about this auto shutoff relay
Old Jun 11, 2005 | 09:20 AM
thump186's Avatar
thump186
my guess would be with a security issue do to the fact that you stated when you unlock the passanger side door it will restart. not sure if haynes or chiltons would be a help to find the relay for it using the diagram. maybe if you have an adio shop nearby they can help find where as they do remote starters and alarm installs they may have access or even know where the module is located.
Old Jun 12, 2005 | 06:17 PM
JCswm's Avatar
JCswm
ORIGINAL: randy789
pull the drivers door panel off with the window UP. there should be a 2 wire sensor that's clipped on to the back of the drivers door lock tumbler, the sensor has failed or fallen off.... replace it & see if that helps your starting problem. IMO
Old Jun 14, 2005 | 03:42 AM
randy789's Avatar
randy789
thanks for the info guys will try these out and see what happens will update later thanks again
