wont fire up
Old Mar 14, 2004 | 10:02 AM
dqkid's Avatar
dqkid
Default wont fire up
i am working on a 78 dodge truck with 318. it is not getting fire at plugs. replaced cap coil even distributer out of a running 318. everything is hot going in to dist. but wont come out. just got on project and i know for a fact there are almost no NEW problems with vehicles just ones that havent happened to me. so i know some one has the answer that i cant find.
Old Mar 14, 2004 | 01:01 PM
charlie1935's Avatar
charlie1935
Default RE: wont fire up
Have you checked to see that the rotor is turning when cranking engine?
Old Mar 14, 2004 | 01:33 PM
dqkid's Avatar
dqkid
thanks for reply charlie1935. i have just gotten involved with this problem and last question i asked owner was "is rotor turning", he said it was,and this is a gearhead guy, but i dont think he has had much MOPAR experience. it will be a couple of days before i can get back on it and i will double back on everything he has tried. sometimes you cant see the forest for the trees, dqkid
Old Mar 15, 2004 | 07:15 AM
71RoadRunner's Avatar
71RoadRunner
If you are getting spark out of the coil and to the distributor, then the problem has to be in the distributor.
Old Mar 15, 2004 | 01:28 PM
Deleted User's Avatar
Deleted User
Default [Deleted]
[Deleted by Admins]
Old Mar 15, 2004 | 01:33 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I'd vote for the distributor...[sm=smiley24.gif]
Old Mar 17, 2004 | 02:26 PM
charlie1935
Also be timing chain. If the plastic are striped it won't go. Could have jumped a few teeth on the gear too.
Old Mar 17, 2004 | 03:46 PM
youwho's Avatar
youwho
im with roadswimmer. i had the same problem with an 85 ford and replaced everything trhat could be replaced. i never even heard of a coil pickup until the parts guy told me about it. 30 bucks and three hours of beat the daylights out of my distributor, the ole ford was runnin again. hope this helps duane
Old Mar 17, 2004 | 11:23 PM
426cuda's Avatar
426cuda
If you replaced the cap, coil, and distributer then it could (rarly) be the plug wires... also check your timing...
Old Mar 19, 2004 | 03:12 AM
71RoadRunner
ORIGINAL: charlie1935
He said,"it is not getting fire at plugs". Even if it jumps time, it will still provide spark, it will just fire the plugs at the wrong time.[sm=smiley2.gif]
