losing power after 5-6 miles???
Old Jul 30, 2005 | 03:33 AM
aepowell's Avatar
aepowell
Default losing power after 5-6 miles???
The truck is a 98 1500 360 auto. Heres the problem. After 5-6 miles the engine starts bogging down to 1500 rpm max. It will idle fine but it will only rev to 1500 rpm. If I let it set for a half hour it will run fine again for a while. The only code that shows up is for the speed censer. The speedo doesn't work untill 55 mph and the abs and brake lights are on in the dash. I had to have it towed home last week. It statrd and ran fine when we got it home. Thanks for you help.
aepowell
Old Jul 30, 2005 | 04:39 PM
kroetsch's Avatar
kroetsch
Default RE: losing power after 5-6 miles???
my 98 5.9 does sort of the same. about 1/2 nile from my house in same spot everyday it bogs and sputters for about 30-50 seconds you pull over the go drive and its fine. untill next day at the EXACT same spot. let me know what you come up with
Old Jul 31, 2005 | 03:25 PM
pembroke dude's Avatar
pembroke dude
Sounds like yous should get your cat convertors checked. A simple exhaust back preasure check should let you know if the convertor is starting to plug up.
let me know what yous find.
