Fuel problem. need help!
Old Aug 2, 2005 | 09:58 PM
KB8's Avatar
KB8
Default Fuel problem. need help!
Ok I have a problem with my 2000 dodge neon. When the car is at idle in drive or is going slow the car does not get enough fuel and spudders. When I floor the car it starts to go fine but at times the atl. light will flash on and off and then just go off. When sitting in idle i can feel the car spuddering. Ive been told to change my fuel filter and that i might be running on 3 cyl. insted of 4. If anyone can help please do!!1 Thanks
Old Aug 8, 2005 | 01:52 AM
hydrashocker's Avatar
hydrashocker
Default RE: Fuel problem. need help!
Try to replace your spark plus with OEM Champion plugs. If that doesn't work get some Mopar or good named wires. I had that same problem in my older Neon I replaced both and it worked wonders.
Old Aug 8, 2005 | 04:24 AM
roachnigga's Avatar
roachnigga
Agree. Also, changing ya fuel filter wont hurt either.
