persistent overheating.. help!
Old Aug 16, 2005 | 10:44 PM
Dodgerzzgal's Avatar
Dodgerzzgal
Default persistent overheating.. help!
I already replaced my head gasket 2 times for my 01 Neon, and this last time I installed a new cylinder head. I started having overheating problems at just 30,000 miles. Does the usually cold wheather has an effect on this? I already replaced the temperature sensor, position sensor, O2 sensor, air filter but still to no avail.
I want to replace the cylinder head, radiator cap and support, and 4 cyl condenser please help me to find budget friendly shop as I am already having financial trouble with all the parts replacements.
Old Aug 17, 2005 | 02:37 AM
s22479a's Avatar
s22479a
Default RE: persistent overheating.. help!
When you replaced the head/headgaskets did you check any of the cooling system for the cause of the origional failure? The neon waterpumps are usually very reliable and have a small failure rate however the thermostat design could have been better. We see an occasional failure with those. The fans also have a tendency to work intermittently and because the engine controller does not monitor fan relay output ,only relay low-side, it will not show a DTC for fan failure. Another place to look is for cold spots in the radiator. A partial blockage can cause an elevated operating temperature without being severe enough to peg the needle. If this lasts long enough gasket failure and/or head damage can result. I hope this helps.
Old Aug 17, 2005 | 03:56 AM
kev_stratus's Avatar
kev_stratus
We suggest that you first put a 50 to 50 mix of water to coolant in your radiator and then check to make sure the radiator fan is working properly. Go check this out: (Auto Parts Discount)
Condenser
you can check this, now is the righ time to buy one it's half the original price.
Old Aug 23, 2005 | 08:47 PM
Dodgerzzgal
Hey guys! after a few days of agonizing repairs and replacements I'm back to the good 'ol fast and fearless driving , thanks for all the help, it really saved me from further headaches!
Old Aug 29, 2005 | 07:16 PM
NCAD's Avatar
NCAD
So what did you fix?
