cold air intakes
Old Aug 24, 2005 | 11:38 AM
drjgarage's Avatar
drjgarage
Default cold air intakes
Which CAIs have you used and what kind of results have you had? What is you engine size and what is the vehicle?
Old Aug 24, 2005 | 02:16 PM
techmanbd's Avatar
techmanbd
Default RE: cold air intakes
When I had my silverado 5.3 ltr, I had one called Full Throttle with K&N filter. easy to install. There's a little increase in performance and got a little better gas mileage.
Old Aug 24, 2005 | 04:46 PM
casper's Avatar
casper
What car or truck are you looking to put this CAI on??
Old Aug 24, 2005 | 06:53 PM
drjgarage's Avatar
drjgarage
2003 dakota, 3.9. It looks to me that the air tubes from inlet and tube to manifold are big enough. Think that just K&N filter would be good enough???
Old Aug 24, 2005 | 07:08 PM
techmanbd's Avatar
techmanbd
That is what my Full Throttle was. It was just a connector tube with the filter. Because the hoses were the same size all the way through. Unlike ford where it tapers, then you have to replace all the tubing to the intake manifold.
Old Aug 25, 2005 | 08:14 PM
drjgarage's Avatar
drjgarage
It seems that the truck has a large air tube to the intake and also into the fender. The air box is large also. Is this sufficient?
ORIGINAL: drjgarage
