Window SCREEEEECH
Old Aug 30, 2005 | 03:38 PM
PARoadRunner's Avatar
PARoadRunner
Default Window SCREEEEECH
Ive got power windows on my 96 strat. They all work, but the right front window makes a terrible screeching noise as the window goes up. The window only makes this noise when going up and only when the window is lowered more than halfway. It sounds like bad chalk rubbing on a blackboard. And its LOUD. The window goes up and down normally, there are no scratches on the glass that I can see. What could this be? Could it need some oil? Anyone have this problem with their windows?
Old Aug 30, 2005 | 04:00 PM
Drew's Avatar
Drew
Default RE: Window SCREEEEECH
sounds like the regulator could use some grease. then after you do that window you'll be amazed how much better that one works and grease up the rest
Old Aug 30, 2005 | 09:24 PM
PARoadRunner
Thanks, but how exactly do I go about greasing up the regulator? (First car, I dont know anything)[sm=huh.gif]
Old Aug 31, 2005 | 10:32 AM
Drew's Avatar
Drew
best thing I ever did with my little yoda was get a haynes manual. it will tell you everything about your car and how to fix it.
second, this will involve pulling the door panel off to acess the workings of the window regulator
here is a pic to give you an idea of what your looking for, the best way to do it would be to get some white lithium grease and spray it on any part that moves against something else.
Old Aug 31, 2005 | 06:36 PM
PARoadRunner
k, I will have to try that this weekend or next. It definately sounds like its the window itself thats making the screech noise somehow, but I could be wrong. Will I need glue to reattach the door panel?
