CEL 0456 - 2000 Neon (it's not the gascap)
Old Oct 5, 2005 | 08:52 PM
boxcutta's Avatar
boxcutta
Default CEL 0456 - 2000 Neon (it's not the gascap)
My 2000 Neon SOHC Highline has a perpetual check engine code 0456. It's been well over a year. I'll clear it and within a few hundred miles it's back.
I know this code, (minor emissions leak or something) is usually due to the gascap not being clicked tight. I always make sure mine is closed properly, so I recently bought a new Mopar gascap and the problem is still there.
What else could this code be from?
I mentioned in a previous thread my car feels like it needs a tuneup. I was thinking the o2 sesors, wiring harness, plugs or timing belt, but these all have codes of their own, no?
It has 126k miles, and the only engine mod is a K&N filter (and R/T exhaust).
Any thoughts?
TIA.
Old Oct 6, 2005 | 02:02 AM
tenntech's Avatar
tenntech
Default RE: CEL 0456 - 2000 Neon (it's not the gascap)
Any leak any where in the evap system can set this code and there is no easy way to locate it. It could be anything from a split hose to a fuel tank. The last neon I fixed with this code was a purge solenoid, but it would probably be cheaper to let a dealer fix it rather than to guess.
