check engine light on
Old Oct 26, 2003 | 11:12 PM
kassab's Avatar
kassab
Default check engine light on
hi</P>
i have dodge spirit 89 auto,4 cyl 2.5 l..</P>
last time i fixed the timing belt,now when i drive the light check engine is on and the oil light is onand on till i turn the ignition off and start again.i check the oil it is max..no need for oil. what is wrong?</P>
thank you</P>
</P>
Old Oct 28, 2003 | 11:57 AM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
Oil Pressure Sending Unit could be going bad, causing the Oil Light... and if the engine 'thinks' it's not getting oil, could throw the Check Engine Light too... I'm not sure on the engine light, so start with the oil light first.
From the dealership is about $34.00...
~Amanda
