1999 Dakota 5.9 R/T
Old Dec 10, 2005 | 09:47 PM
karty's Avatar
karty
Default 1999 Dakota 5.9 R/T
OK so as the title says I have a 5.9 R/T.
The tranny has been acting up in the last few days and having an ir-regular shift pattern.
Fluid just changed 5k ago and the level is full and the truck is not beaten.
Is this gonna cost me a few $$$$?
Should I start looking for a tranny?
What is the "Model "number of the that came in these trucks?
Old Dec 11, 2005 | 07:03 PM
hydrashocker's Avatar
hydrashocker
Default RE: 1999 Dakota 5.9 R/T
It could be your governor actuator switches. I think I would look at replacing the transmission output sensor and rear speed sensor.
Old Dec 11, 2005 | 11:54 PM
karty's Avatar
karty
Could you point out where these items are located on the truck?
Old Dec 12, 2005 | 04:29 PM
hydrashocker
The transmission output sensor Is located on the outside of the trans. The rear speed sensor is on the rear end. Now I'm talking about a Durango not a Dakota. But they should be similar. The governor actuator switches should be on the valve body inside the trans.
Kensai <----- in the Durango 1st generation forum has some info you could ask for, or search for his past posts.
