checking as ecu
Old Feb 25, 2006 | 04:36 PM
ernie74's Avatar
ernie74
Default checking as ecu
I hooked an amp meter to a wire under the dash of my 91 dodge caravan with a 3.3, automatic. The wire had a factory lable (ignition feed) when I started the engine with amp meter still connected, the engine died and smoke came rolling out from under the hood by the drivers side front fender. By the time I got the hood open I couldn't see just where the smoke came from, when I first saw the smoke I heard a pop noise from the fender area. Did I fry my ecu, or is there a fuse link some where that got blown.
Old Feb 27, 2006 | 02:19 AM
casper's Avatar
casper
Default RE: checking as ecu
A meter should not have blown a fusible. How much smoke was there?
