Kicking in, Kicking out
Old Feb 28, 2006 | 08:41 AM
cairtaker's Avatar
cairtaker
Default Kicking in, Kicking out
How about an idea from all you Dodge Fans Please.
My cooling fan is kickin in and out about every 6 secs when the thermostat controls are on. When they are completely off then nothing. also, the A/C stopped working. Any suggestions?
Thank you for any and all help
99 dodge ram 1500, 5.2, w/ AC, 2wd
Old Feb 28, 2006 | 07:03 PM
06ChargerSXT's Avatar
06ChargerSXT
Default RE: Kicking in, Kicking out
could be a relay gone bad also check fuses.
Old Mar 1, 2006 | 04:52 AM
Chump's Avatar
Chump
Could be low on freon, as I recall the fan relay needs to know that there is sufficient pressure in the A/C circuit via a pressure switch. If the freon goes too low the switch will not make and neither will the fan relay when the A/C is turned on. This shouldnt affect normal fan cooling for the regular engine cooling cirtcuit.
Old Mar 4, 2006 | 12:34 AM
CarputerGeek's Avatar
CarputerGeek
ORIGINAL: Chump
That's exactly what I thought, I think you'll also see/hear the AC compressor kicking on and off.
Let us know!
