Engine light on
Old Mar 6, 2006 | 03:30 PM
Wtfd32's Avatar
Wtfd32
Default Engine light on
my check engine light came on on my 1999 dodge ram 1500
I had it scanned and it said P0308 Cylinder 8 Misfire
What can cause this is it a bad spark plug maybe? i have noticed it is hesitating and idleing kind of rough
Old Mar 6, 2006 | 11:12 PM
06ChargerSXT's Avatar
06ChargerSXT
Default RE: Engine light on
Did you ever have the engine DE carbonized
Cleaned out.
Try some Fuel system cleaner try the one from dealer
OR try the Chevron system cleaner.
Old Mar 11, 2006 | 09:51 PM
ramdude's Avatar
ramdude
I have a 1996 dodge ram indy edition and my engine light kept coming on and it also showed what your saying. somehow or another it ended up being my map sensor.
Old Mar 16, 2006 | 01:27 AM
buckw1's Avatar
buckw1
Swap the plug and spark plug to another cylinder and see if misfire code moves to that cylinder. If so then time a full tune-up. If code stays same then I would suspect its time for a valve job, they are know for dropping valve seats and/or breaking valve springs. Compression test or leak down test can confirm.
Buck
