Tranny problems....?
Old 03-16-2006, 09:54 PM
duneschick's Avatar
duneschick
duneschick is offline
Default Tranny problems....?
I just traded in a 1999 Dodge Ram 2500 Quad with 5.9 V8 auto. I received a 2001 Dodge 2500 Quad Cummins 24 Valve, Six Speed. Well I have had it about 1-1/2 months and I am having probs with the transmission. I replaced the clutch slave and master cylinder cause second gear was hard to go into. Now when I am driving, third gear is kindof hard to shift into. I grew up with standards so I know how to drive! Has anyone had these kind of probs and do you know what I can do? Truck has 66k miles on it
[IMG]local://upfiles/31532/ADBB4DD764624A6D8FC662D2B8190CF7.jpg[/IMG]
Old 03-17-2006, 07:40 AM
silvercoupe97's Avatar
silvercoupe97
silvercoupe97 is offline
Uber Moderator
Dodge Forum Moderator
Default RE: Tranny problems....?
How old is the transmission fluid? Was that changed the same time the master and slave cylinders? Was the clutch rod adjusted as well? <--Most likely not the problem, but I just have to ask. Granted, I have a car with a stick but the basics are the same.
Old 03-17-2006, 01:17 PM
duneschick's Avatar
duneschick
The shop and my boyfriend said the fluid looks great. And also on these trucks there is no adjustments to be made. I am thinking that maybe the bolts on the tranny and transfer case are loose. I read in another forum that some of the dodge's have that problem. When I drive down a highway my shifter moves more than it used to. Either that or I bought a lemon.
[IMG]local://upfiles/31532/AAC208E82F0441EE803EE82BC35D0198.jpg[/IMG]
Old 03-17-2006, 06:09 PM
silvercoupe97
Uber Moderator
ORIGINAL: duneschick
That may have something to do with it. That happens to cars too, as a matter of fact mine is starting to do that a bit (a tiny, irritating, bit).
Quick Reply: Tranny problems....?
