What can be done for an 00 Intrepid?
Old Mar 20, 2006 | 02:30 AM
Kitulu's Avatar
Kitulu
Default What can be done for an 00 Intrepid?
There is NO clearance under the hood. At all. None. SO, what can be done to increase power in the 3.2? I have look on most of the links that I found here, but there seem to be very few aftermarket parts for these cars. Does anyone know if parts for another car would fit? And work? Also, my engine has 84,000 on it, but still runs solid. Is it worth it to rebuild these engines?
Old Mar 20, 2006 | 02:39 PM
DodgeRam318_4bbl's Avatar
DodgeRam318_4bbl
Default RE: What can be done for an 00 Intrepid?
Does K&N (or anyone else) make a CAI system for it?
Old Mar 22, 2006 | 10:18 AM
thump186's Avatar
thump186
It is possible to turbo the 3.2. There is also the plymouth prowler gears. There is also body kits ect... You can also look into having the TB ported to allow more air.
Old Mar 23, 2006 | 02:39 AM
Kitulu's Avatar
Kitulu
So, do you know any links?
Old Mar 23, 2006 | 09:44 AM
thump186's Avatar
thump186
for body kits you have www.andysautosport.com http://www.showcars-bodyparts.com/intrepid.html . The turbo kit would have to be custom. I can get some pics of an example if you'd like. If your looking for a 10 second car good luck but if you want a nice looking cruiser then you found it. As for the gears goto www.prowlerpro.com and click on gears. they will work to lower the gear ratio.
Old Mar 27, 2006 | 07:58 PM
Kitulu's Avatar
Kitulu
Thanks ffor the links, I appreciate it...definitly something to look into when I get some more petty cash, lol. I did have a thought though...given that mitsubishi and dodge are the same company now, and there are a ton of aftermarket stuff for the eclipse....if the eclipse has a 6 cyl, then would aftermarket parts for that 6 cyl fit the 6 cyl in the trep?
