power window repair
Old Mar 22, 2006 | 09:35 PM
upaway's Avatar
upaway
Default power window repair
92 Dodge Ram 2500 :no power to door power window switch. All fuses in glove box are good. Can anybody help me.
thanks, Upaway
Old Mar 22, 2006 | 10:55 PM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Default RE: power window repair
Did you check at the plug or is that what you meant? For example...did you remove the plug and checked the contacts? I don't mean to make you sound like a dolt, because that's probably what you did, I just want to get the obvious out of the way. Yours may be more complex but I was able to open mine up and clean the contacts.
Old Mar 23, 2006 | 02:35 AM
Kitulu's Avatar
Kitulu
Yup...happened to me on my old mercury I had in high school....power windo motor quit working, and after we disconnected and cleaned the contacts, and reconnected, it worked fine.
