87 Dakota headlight switch
Old Apr 24, 2006 | 07:40 PM
rustygardhouse's Avatar
rustygardhouse
Default 87 Dakota headlight switch
I have an early 87 Dakota LE. About every year and a half, both headlights and only the headlights quit working. The headlight switch tests OK with a meter but the headlights only work when the switch is changed.
Is this familiar to anyone?
Does anyone ahve a headlight wiring diagram for an early 87 Dakota so I can try & trouble shoot this bug?
Thanks
Rusty
Old Apr 26, 2006 | 01:02 AM
Rivalry's Avatar
Rivalry
Default RE: 87 Dakota headlight switch
Are you testing the switch in circuit or out?
If you replace the switch and it works, then it would seem likely the switch is bad, Unless a connection is giving you a fit.
