break squeal
Old Apr 27, 2006 | 11:59 PM
pythonbunny's Avatar
pythonbunny
Default break squeal
i had my pads replaced about two months ago and they started to squeal real bad so i took the pads off put some of that brake squeal lubricant on it and it came back so i bought all new rotors and pads on the internet the drilled and slotted ones put them on and a few days later the freakin squeal is back and now it clicks when the slots hit the pads in front, this is a 2003 ram 1500 4x4 is there something that im missing when i put on the lube or what and the click is irritating me too. what else can i do? its really bothering me sounds like crap!!!!
Old Apr 28, 2006 | 03:04 AM
buckw1's Avatar
buckw1
Default RE: break squeal
Differnet brand pads, preferably something ceramic.
Old Apr 28, 2006 | 05:35 AM
silvercoupe97's Avatar
silvercoupe97
Uber Moderator
Where you put the gel lubricant can be the difference between squeaking and not squeaking. I hate the squeaking, I normally put it on at every contact point of the pad.
Old Apr 28, 2006 | 08:36 PM
pythonbunny
well today i got front ceramic pads i cleaned the rotors with brake cleaner all the pins and shims , then on every contact point put this ultra lube stuff and still i have a freakin squeal in front im at wits end with this thing is there anything else i can do!?
Old May 8, 2006 | 02:52 AM
reiderr's Avatar
reiderr
Just out of curiosity, why wouldn't you resurface or replace the rotors when you replaced the pads?
Roger...
