No engine spark
Old May 22, 2006 | 12:34 AM
POP's Avatar
POP
Default No engine spark
Got a 95 Stealth with a viper remote start security system. Everything is working great then I come home one evening go to leave the next morning and I have no fire to the plugs when I try to start the car. Engine turns good but does not even attempt to crank????????
Old May 22, 2006 | 12:38 AM
POP's Avatar
POP
Default RE: Stealth transmission
Got a second issue. I had planned to take this to the dealer but thought I would get opinions first. About 2 weeks ago my 95 Stealth RT with an automatic trans quit going into overdrive. As long as I have the overdrive tuned off it shifts just fine. Turn the overdrive on and it goes into neutral in stead of overdrive. Any ideas?????
Old May 22, 2006 | 01:39 AM
Rivalry's Avatar
Rivalry
Default RE: No engine spark
Well, did you wire in the remote start system? If not its hard to say how whoever wired it in did. If you arent getting any spark though could be a bad coil, points, distributer, or timing sensor.
Might want to start with fuses though.
