02 dakota rpm increases then drops when in cruise control
I have a 2002 dakota 3.9 with an automatic. I just noticed when im doing about 60 down the highway with cruise control on that the rpms jump up about 200 rmps every few seconds and then kick back down. it is really noticeable. could this be the cruise control module going bad. i did put new plugs in last week before the problem started. they are bosch platinums. could the plugs be the problem? the whole issue started after i put them in. any ideas would be helpfull thanks!
What type of Bosch platinums did you put in? The regular ones or the +4 models? The +4s are not recommended for trucks, and have been known to cause pinging and misfires [:'(] Bosch platinum plugs in general aren't the best for a distributorless ignition system, as they tend to wear out more quickly and can often last only 10 to 20,000 miles. [:'(] Autolite makes a much better platinum plug line that seems to hold up to the constant firing of a DIS. Champion copper core plugs are also a good choice. The champion truck line, while costing slightly more, is also an excellent choice.
What did you gap the plugs at before you installed them?
the plugs are just the normal platinums, not the +4s. the gap is .040 also. someone mentioned that ut could be the TPS. what exactly is that... thanks
You could try re-gapping them to .035 or .038. From what I've heard, the 3.9 Magnum doesn't run so smooth with the stock ignition when they're gapped above .038 [>:]
TPS = Throttle Position Sensor
Here's a stock definition for you...as I can't put it any better than it does...
It is located on the side of the throttle body. It's common for them to get dirty and cause idiling and shifting issues.
The Throttle Position Sensor (or TPS) tells the computer how hard you’re stepping on the gas pedal so that the computer can match fuel delivery to the volume of air and ignition timing load. On electronically shifted transmissions, this sensor is intricately involved in the shifting strategy.
That 200-300RPM "surge" is likely the torque converter clutch locking and unlocking. Whoever told you about the TPS being the possible problem is right on target. It's pretty common for them to cause this.
I'd replace the Throttle Position Sensor (TPS) if I were you.
Champion plugs are the best way to go in my opinion, I have them in my truck right now, no pinging knocking or nothing. If your TPS was dirty or not reading right wouldnt it set a code?
Trending Topics
ORIGINAL: 01RamSport
