what model trans is in my Ram?
Old Jun 13, 2004 | 01:36 AM
ductruck's Avatar
ductruck
Default what model trans is in my Ram?
any way to determine what model trans is in my '93 Ram 150 Clubcab LE auto w/od behind a 5.2l magnum v8
I want to put a deep pan on for towing & I'm not sure how to determine model #.
tony
Old Jun 13, 2004 | 01:04 PM
JCswm's Avatar
JCswm
Default RE: what model trans is in my Ram?
post your vin #
or count the bolts in the pan and call an auto parts store
Old Jun 13, 2004 | 04:34 PM
dodgemech's Avatar
dodgemech
93 1/2 ton with a 5.2 is almost for sure a A500. A518 were 5.9 or H/D 5.2 with tow package. Look at the pan, if it almost square shaped it is A500, if it has a very pronounced "kick" out on the R/F corner it is a A518.
Old Jun 13, 2004 | 04:45 PM
ductruck's Avatar
ductruck
I'll look under it today!
VIN # 3B7HE13Y2PM131661
tony
Old Jun 16, 2004 | 11:34 PM
Parts/Service's Avatar
Parts/Service
BCES BATTERY - 600 AMP MAINTENANCE FREE BGJS BRAKES - PWR DISC/DRUM, RR ANTI-LOCK BKGS BRAKES - 11X2.5 REAR DRUM
DGRS TRANSMISSION - 4-SPD. AUTOMATIC,46RH DHAS TORQUE CONVERTER - LOCK-UP DJBS AXLE - FRONT
DMDS AXLE RATIO - 3.55 DRBS AXLE - REAR, CORPORATE 9.25 LD GACS WINDOWS - TINTED GLASS
GBBS WINDSHIELD GLASS - TINTED GCBS GLASS - FRONT DOOR TINTED GEFS GLASS - TINTED QUARTER, VENTED
GNAS MIRROR - REAR VIEW, DAY/NIGHT GVBC ALL VEHICLES W/POWER MIRRORS JCDS SPEEDOMETER - 100 MPH PRIMARY
JJAS LIGHTER - CIGAR LAFS WARNING BUZZER- KEY IN IGN/SEAT BELT LAJS WARNING CHIMES - HEADLAMPS ON
MFDS GRILLE - BRIGHT MHAS WINDSHIELD MOLDINGS - BLACK NAAS EMISSIONS - FEDERAL
NBKS EVAP CONTROL SYSTEM NFES FUEL TANK - 24 GALLON POLYETHYLENE RAAC ALL RADIO EQUIPPED VEHICLES
SBAS STEERING - POWER RACK AND PINION SFAS STANDARD DUTY SHOCKS SGAS SHOCK ABSORBERS - REAR
SJPS DESCRIPTION NOT AVAILABLE SNFS DESCRIPTION NOT AVAILABLE TBBS SPARE TIRE - FULL SIZE
TBMS TIRE CARRIER - WINCH WLBS WHEEL - SPARE, STEEL WLZC WHEELS - ALL ALUMINUM
XPFS PROTECTIVE COATING AND REMOVER YAAS BUILD TO U S MARKET SPECIFICATIONS Z1CS GVW/PAYLOAD RATING
1AAS U.S. DEALER RETAIL 166S ZONE 66-ORLANDO
Optional Equipment
Code Description Code Description Code Description
*R5 SEATS - PREMIUM CLOTH BUCKET -S8 DESCRIPTION NOT AVAILABLE ADAP LIGHT GROUP
AJKP CONVENIENCE GROUP AJPP POWER CONVENIENCE GROUP APCA TWO TONE PAINT - CENTER BAND
ASPP SLT DECOR GROUP BARP ALTERNATOR - 90 AMP CADP SEATS - HIGH BACK BUCKET
CDEP SEAT - HINGED BACK CHEP HEADLINER - DELUXE CKEP CARPET - FRONT SEAT AREA
CKNP CARPET - CARGO COMPARTMENT CTBP CARGO COMPARTMENT TRIM PANEL - LOWER CUCP CONSOLE - FLOOR
DGB TRANSMISSION - ALL 4-SPEED AUTOMATIC ELF ENGINE - 5.2L V8 MPI GFDP WINDOW - REAR, SLIDING
GPPP MIRRORS - POWER 6 X 9 BRIGHT HAAP AIR CONDITIONING HGAP INSULATION - HOOD
JBBP BEZEL - INSTRUMENT PANEL, WOODGRAIN JHAP WINDSHIELD WIPERS - VAR INTERMITTENT JJBP HORNS - ELECTRIC, DUAL NOTE
JKAP GLOVE BOX - LOCKING JPAP WINDOWS - POWER JPBP LOCKS - POWER
KBGP DESCRIPTION NOT AVAILABLE K1XP DESCRIPTION NOT AVAILABLE K17P STRIPE/BADGE/MOLDING
K2XP DESCRIPTION NOT AVAILABLE K27P STRIPE/BADGE/MOLDING LAAP LAMP - IGNITION TIME DELAY
LBAP LAMP - MAP/COURTESY LBCP LAMP - GLOVE BOX LBDP LAMP - ASH TRAY
LDAP LAMP - UNDERHOOD LMAP HEADLAMPS - HALOGEN LPEP LAMP - CARGO
MBFP BUMPER - REAR, BRIGHT W/STEP PADS MKCP DESCRIPTION NOT AVAILABLE MPBP APPLIQUE - TAILGATE, BLACK
MWDP TAILGATE- REMOVABLE, CALIPER LATCHES NHMP SPEED CONTROL NMC ENGINE COOLING - HEAVY DUTY
PGFA EMERALD GREEN PEARL COAT QV4A DESCRIPTION NOT AVAILABLE RAY RADIO - AM/FM CASSETTE W/EQUALIZER
RCDP SPEAKERS - FOUR SCEP STEERING WHEEL - 2-SPOKE SOFT FEEL SHA STABILIZER BAR - FRONT
SUAP STEERING COLUMN - TILT TSFP TIRES - P235/75R15 OWL ALL SEASON TZAP GOODYEAR BRAND TIRES
WJC WHEELS - 15 ALUMINUM XBSA PICKUP BOX YGAA WITHOUT BILLABLE FUEL
2TEA CUSTOMER PREFERRED PACKAGE 2TE 26E CUSTOMER PREFERRED PACKAGE 26E 3VRA CUSTOMER PREFERRED DISCOUNT
6CS LABEL - CANADA SPECIFICATIONS
This is a build sheet of your truck. You have a 46RH transmission. hope it helps............
Old Jun 17, 2004 | 02:27 AM
ductruck's Avatar
ductruck
thanks! I got all the scoop now!
tony
