89 Omni wont start???
Old Jul 28, 2006 | 03:58 AM
Sublime69's Avatar
Sublime69
Default 89 Omni wont start???
I have an 89 omni and its been sitting for a couple months. It started up two days ago but today i went to start it and it just cranked. I found that it has no spark from the coil. So i replaced the coil and still nothing.. and one have any suggestions? could it be a bad ecm?
Thanks
Old Jul 28, 2006 | 04:45 AM
dodgerules86's Avatar
dodgerules86
Default RE: 89 Omni wont start???
First, check for blown fuses.
Than, I think your car might have an automatic shutdown (ASD) relay. Swap that out with a KNOWN GOOD relay (or, a new one).
After that, post back with results.
Old Jul 28, 2006 | 06:51 PM
Sublime69's Avatar
Sublime69
do you know where that ASD relay is located?
Old Jul 29, 2006 | 07:42 PM
The Burning Rom's Avatar
The Burning Rom
Did you replace the pick-up plate in the distributor?
It's a common problem on the Omnis
Old Aug 24, 2006 | 11:54 PM
chryslertech's Avatar
chryslertech
check timing belt? If belt breaks or teeth strip off, distributor wont turn and you will get no spark. Take off distibutor cap and have a friend crank over engine to see if rotor button turns. Be sure to ground coil wire though or you can fry the pcm.
