2000 Durango A/C problems
First off I'm glad there is a forum for Durango owners and have read up on several posts and could not find a problem like mine.
My 2000 Durango 5.2 SLT is not blowing any cool air at all it went from cold to hot while I was driving it to work, it started off with the A/C blowing cold air while I was driving and then it started to get warmer as I was driving to completely hot and has been hot ever since and thats been several days now.
The compressor engages when I turn on the A/C selector switch to the on postion and disengages when the A/C selector switch is in the off postion. This has me scratching my head, I know from the past if the compressor is not engaging there is a low refrigerant pressure in the system, it was in need of a recharge of refrigerant.
I know I need to check the pressure in the system, but what would cause it to blow hot air even though the compressor is still engaging like that ?
any helpful tips would be great
PS found a TSB # 24-03-96 A/C does not cool A/C clutch engaged Check PCM with DRB III, I cant get a viewable page on this particular TSB #
again any help would be great
"if the compressor is not engaging there is a low refrigerant pressure in the system"
that's not true.
Drain the a/c system, vacuum it down, fill it with the exact amount of 134a it needs, see label under the hood somewhere. then add dye. run the a/c for a day, then use a blacklight to check if the dye is leaking anywhere...evaporators go bad allot! shine the blacklight at the evap drain tube.
Does anyone know of a forum similar to this one but for Chrysler-Dodge-Jeep Dealer techs only?
that's not true.
