Amsoil Questions and answ
Old Dec 4, 2003 | 03:30 PM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
Default Amsoil Questions and answ
1994 Dodge Ram 1500 5.9L 360
Can you give me totals on 'switching'? And how do I do dual bypass? LOL!
~Amanda
Old Dec 4, 2003 | 03:40 PM
SyntheticsMan's Avatar
SyntheticsMan
1994 DODGE TRUCKS RAM 1500 PICKUP 5.9L 8-cyl VIN Code Z
FILTERS
Oil Filter......SDF42
Oil Vapor Filter......CB27
Air Filter......TS29
Fuel Filter......N/S
PCV Valve......HV113
Trans......TF42
BOSCH SPARK PLUGS
Plug......B4418
Wire......B09715
BOSCH WIPER BLADES
Driver side......B40920
Passenger side......B40920
CHASSIS LUBRICATION
Two-wheel drive
6-9 Fittings,0 Plugs..........LB
Series 2000 Synthetic Racing Grease (GRG)
Synthetic GH Series Heavy-Duty EP Grease (GHB, GHD)
Synthetic GL Series Multi-Purpose EP Grease (GLA, GLB, GLC)
Four-wheel drive
5-11 Fittings,0 Plugs..........LB
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Series 2000 Synthetic 0W-30 Motor Oil (TSO)
SAE 10W-30 Synthetic Motor Oil (ATM)
Synthetic XL-7500 Motor Oil (XLF, XLM, XLT)
Above 0°F......10W-30[1]
Below 32°F......5W-30
Manual Transmission,AX-15.....GL-5
75W-90
Series 2000 Synthetic Gear Lube (TGR)
Synthetic Gear Lubes (AGR, AGL, AGT, ALU, AGO)
Manual Transmission,NV3500.....GLS[2]
SAE 5W-30 SYNTHETIC MOTOR OIL (ASL)
Series 3000 Synthetic 5W-30 Heavy Duty Diesel Oil (HDD)
Manual Transmission,NV4500.....GL-4
75W-85[3]
Automatic Transmission.....AP4[4]
Synthetic Automatic Transmission Fluid (ATF)
Differential, Front .....GL-5
80W-90, 80W-140, 85W-140
Differential, Rear .....GL-5*[5][6]
80W-90
Differential, Rear Dana 60 Or Spicer.....GL-5*[6]
80W-90
Differential, Rear Others.....GL-5*[6]
Transfer Case,.....AF3
Transfer Case,.....AP3
Fluids
Power Steering Fluid.....PS
Power Steering Fluid - Not Available Through Amsoil Click here for more information
Brake Fluid.....HB
Hydraulic Brake Fluid, DOT-3, DOT-4 or SAE J1703 - Not Available Through Amsoil Click here for more information
Clutch Fluid.....HB
1. 10W-30 is preferred.
2. GLS is a special gear lube, Mopar part no. 04874464.
3. GL-4 synthetic gear oil, Mopar part no. 4874459
or Castrol Syntorq are recommended.
4. Daimler Chrysler Corp. recommends that all vehicles with
Chrysler automatic transmissions be serviced with ATF+4
Automatic Transmission Fluid.
5. CS IDENTIFICATION: Lift both rear wheels, turn a wheel and
other will rotate in same direction.
6. W/ Cs, add 6.5% Mopar Trac-loc additive.
CAPACITIES
Engine, with filter..........5.0 quarts[1]
Cooling System, Initial Fill..........20.0 quarts
Automatic Transmission, Initial Fill..........4.0 quarts[2]
Automatic Transmission, 46RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, 47RH Initial Fill..........4.0 quarts[2][3]
Automatic Transmission, Total Fill
3 speed ..........8.6 quarts
4 speed ..........11.0 quarts
Manual Transmission, AX-15..........6.5 pints
Manual Transmission, NV3500..........4.2 pints
Manual Transmission, NV4500..........8.0 pints
Differential, with 7.25 ring gear Front..........3.0 pints
Differential, 2WD with Dana 60 Rear..........6.3 pints
Differential, 4WD with Dana 60 Rear..........7.2 pints
Differential, with 7.25 ring gear Rear..........3.0 pints
Differential, with 8.25 ring gear Rear..........4.4 pints
Differential, with 9.25 ring gear Rear..........4.9 pints
Differential, with Dana 44 Front..........5.7 pints
Differential, with Dana 60 Front..........6.3 pints
Transfer Case,NP231, 233..........2.5 pints
Transfer Case,NP241HD..........6.5 pints
Transfer Case,NP241..........4.6 pints
Transfer Case,NP241 W/ Dsl..........6.5 pints
1. After refill check oil level
2. With engine automatic transmission operating temperature, shift through all
gears. Check fluid level in NEUTRAL and add fluid
as needed.
3. TOTAL FILL is for 47RH trans only.
TORQUES
Oil Drain Plug.....25 ft-lbs
Transfer case
Fill Plug.....30-40 ft-lbs
Drain Plug.....30-40 ft-lbs
Manual Transmission NV3500
Fill Plug.....14-20 ft-lbs
Drain Plug.....14-20 ft-lbs
Manual Transmission NV4500
Fill Plug.....25-35 ft-lbs
Drain Plug.....25-35 ft-lbs
Manual Transmission AX-15
Fill Plug.....27 ft-lbs
Drain Plug.....27 ft-lbs
SERVICE INTERVAL
http://www.amsoil.com/lit/g1490.pdf
So what are you Temperature extremes?
We'll figure what oil you want then I'll run down the costs for ya.
Old Dec 4, 2003 | 04:20 PM
Iggster's Avatar
Iggster
ok I have a 1994 eagle talon tsi awd turbo....shoot me the costs if you can...temp ranges from -40 degrees in winter to 95+ degrees in summer
Old Dec 4, 2003 | 04:28 PM
SyntheticsMan
Iggster - which one of these are you, thanks
- 1.8L 4-cyl VIN code B
- 2.0L 4-cyl VIN code E
- 2.0L 4-cyl VIN code F
<edited><editID>SyntheticsMan</editID><editDate>37959.5617476852</editDate></edited>
Old Dec 4, 2003 | 04:29 PM
Iggster's Avatar
Iggster
not sure ...it is the 2.0l 4cyl turbo if that helps</P>
</P>
Old Dec 4, 2003 | 04:50 PM
Dodgegirl19
Lady Administrator
Even though that's alot of info... I have know idea whatmy temperature extremes are... LOL!
So basically I could just by the oil from you and not install anything new on my truck... right? The dual bypass isn't necessary...?
~Amanda</P>
Old Dec 4, 2003 | 04:51 PM
SyntheticsMan
Iggster - choose an oil below......also, if you want the dual remote, it may be hard to find a place to mount it. The kits needs about 8.5wx4.5dx6h inchs of space. of course you can also add the single bypass which would require half the space, but involves extra work to install it. I'll post pics if you'd like.
preferred customer prices
1994 EAGLE TALON 2.0L 4-cyl VIN Code F DOHC
FILTERS
Oil Filter......SDF13 $10.30
Oil Filter Qualifier......2 1/2 In. O.D.
Oil Filter......LF543
Oil Filter Qualifier......3 11/16 In. O.D.
Air Filter......AF913
Fuel Filter......GF288
PCV Valve......HV119
Trans......TF98, Exc. Turbo
Trans......TF132, Turbo
BOSCH SPARK PLUGS
Plug......B4478[1]
Wire......B09083[1]
Plug......B4478[1]
Wire......B09083[1]
Plug......B4478[2]
Wire......B09246[2]
Plug......B4478[3]
Wire......B09246[3]
1. Optional set with red wires and OE type connectors.
2. Includes turbo
3. Includes turbo
BOSCH WIPER BLADES
CHASSIS LUBRICATION
0 Fittings,0 Plugs
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......SJ
Series 2000 0W-30 (TSO) $ 6.45/qt
SAE 10W-40 High Perf (AMO) $ 4.55/qt
Series 2000 20W-50 Racing Oil (TRO) $ 6.45/qt
Grade 2......API*
Above 32°F......20W-40
Above -9°F......10W-30
Below 61°F......5W-30
Manual Transmission,4Wd.....GL-4
75W-85W, 75W-80
Series 2000 Synthetic Gear Lube (TGO)
Automatic Transmission.....AP3
Differential, Rear .....GL-5[1]
-34 to -23°C......80W, 80W-90
Transfer Case,.....GL-4
75W-85W, 75W-90
Fluids
Power Steering Fluid.....AF2
Brake Fluid.....HB
Clutch Fluid.....HB
1. Rear diff is for 4wd models only.
CAPACITIES
Engine, with filter..........4.8 quarts[1]
Automatic Transmission, Initial Fill..........4.2 quarts[2]
F4A33..........7.4 quarts
FA22, 23..........6.5 quarts
W4A32, 33..........7.4 quarts
Manual Transmission, 4WD..........4.9 pints
Manual Transmission, 2WD..........3.8 pints
Differential, Rear..........1.5 pints[3]
Transfer Case,..........1.3 pints
1. Capacity shown includes filter. After refill check oil level
as needed.
3. Rear diff is for 4wd models only.
TORQUES
Oil Drain Plug.....26-32 ft-lbs
Manual Transmission
Fill Plug.....22-25 ft-lbs
Drain Plug.....22-25 ft-lbs
SERVICE INTERVAL
Old Dec 4, 2003 | 04:57 PM
Iggster's Avatar
Iggster
ok this is all a lil foriegn to me.... which would you recomend....I don't race the car but i do drive it regurlarly...when it is not stranded on jack stands due to bad brake calipers.... what is your recommedation and would the overall cost be? and your right...there is NO room in the engine compartment
Old Dec 4, 2003 | 05:14 PM
SyntheticsMan
Amanda, I'm going to make another thread that details the bypass. So everyone can see it there. As far as your oil is concerned, you can get the 5w-30 and be just fine, and the oil filter SDF-42, the bypass is not neccassary, I would also recommend the Engine flush to clean out your engine first.
For your truck , here's your cost.
ASL 5W-30 $4.55 X 6 QT's $27.30 1 extra qt.
SDF-42 Filter $8.80
AEF Engine Flush - $3.45
Preferred customer $10.00 6 months or 1 Year $ 20.00
Sub total - $39.55
tax $2.37
ship $7.75
Total $49.67, either 10 or 20 more depending on your preferred customer option. Preferred customers save about 25%
When your ready to order, we'll just go through the website, it will be much easier.
Old Dec 4, 2003 | 05:32 PM
SyntheticsMan
Iggster - If you have absolutely no room, I'd recommend at least the HIgh Performance 5w or 10w-30's. If your not seeing extreme freezing temps or high's go with the 10w, both cost the same. This package will allow 25k miles on your oil, assuming our engine is mechanically sound, and not already in bad shape. you'll change the filter at 12.5k and the oil at 25k, for additional piece of mind, you can get oil analysis when ever you like, perhaps around 5-7-or 10k to see how the oil is doing. Oil analysis is 18.95 postage paid for PC's (preferred customers)
ASL 5w-30 high performance OR
ATM 10w-30 high performance $4.55 6qt's 1 extra $ 27.30
SDF-13 filter $10.30
AEF Engine flush is 3.45
What state are you in, so I can figure sales tax for ya. your shipping will be 7.75
When your ready to order, go to my website, which is the link at the right . Click Enter online store. Select the items above, if you want the discounts , order a preferred customer program too. While your there, request a free catalog too.
Let me know if this is all clear or not.
Kale
<edited><editID>SyntheticsMan</editID><editDate>37959.6096875</editDate></edited>
