Brakes...
Old Sep 19, 2006 | 08:50 PM
ramman99's Avatar
ramman99
Default Brakes...
My brake and ABS indicator lights (in the dash) have come on, and are staying on. I checked the master cylinder for leaks and found none. I then pulled the rear drums and the brake shoes are in excellent shape. Could I have a sensor out?[sm=confused06.gif]
Old Sep 20, 2006 | 12:06 AM
tenntech's Avatar
tenntech
Default RE: Brakes...
I'm assuming this is a ram judging from your user name. The most comon problem with these was the rear wheel speed sensors. You might post the model vehicle and get a little more detailed information, also check and see if the speedometer works at low speeds.
Old Sep 20, 2006 | 02:58 AM
ramman99's Avatar
ramman99
Ahh, yeah, sorry. It is a ram. '99 1500. My speedometer is acting up until I hit 20 mph,now that you mention it. Where do I find the sensors, and how do I check them (assuming I can)?
Old Sep 23, 2006 | 06:25 PM
tenntech's Avatar
tenntech
The rear wheel speed sensor is located on the top of the rear differential housing and is fairly simple to replace. The only problem you may have is the o-ring get dry and makes the sensor a little hard to pull out. There are some ways to check the sensor and wiring but its nothing simple, I'd just try a sensor.
