check engine light
Old Jul 27, 2004 | 08:35 PM
Spyder's Avatar
Spyder
Default check engine light
My check engine light came on and i used a code reader to find out what the problem was and it turned out to be an output speed sensor circuit malfunction. Do i need to take this to the dealer or could a shop fix this.
Thanks.
Old Jul 27, 2004 | 11:30 PM
JCswm's Avatar
JCswm
Default RE: check engine light
The sensor is only $26.00
If you have tools You could do it yourself!!!
Old Jul 28, 2004 | 07:07 PM
Spyder's Avatar
Spyder
Where is the sensor located? I checked both my manuals and couldnt find where the sensor was at.
Old Jul 28, 2004 | 09:56 PM
JCswm's Avatar
JCswm
On the drivers side of the trans towards the rear, buy a new sensor & look at it before you climb under there.... you'll find it!!
Old Jul 28, 2004 | 11:25 PM
rockadaous's Avatar
rockadaous
Old Jul 29, 2004 | 12:31 AM
Spyder's Avatar
Spyder
What tools will i need to replace this?
and would this malfunctioning sensor cause my transmission to slip?
