2000 Durango turn signal issue...
Old Jan 2, 2007 | 07:31 PM
njChallenger's Avatar
njChallenger
Default 2000 Durango turn signal issue...
Both of the turn signals (and hazzard lights)on a 2000 Durango will "blink" only 3-4 times and then stop. I checked the fuses and they were OK. I suspect the problem is the "[/b]Turn Signal Relay", so I bought a new one. I can't locate the relay switch to replace it, isit located under the dash? Or, under the hood in the driver area? Can anyone make a suggestion? Thanks.
Old Jan 2, 2007 | 07:33 PM
njChallenger
Default RE: 2000 Durango turn signal issue...
Both of the turn signals (and hazzard lights)on a 2000 Durango stopped working. It will "blink" only 3-4 times before stopping. I checked the fuses, they are fine. I suspect the turn signal relay from the fuse box but they said it was not correct. I cannot locatethe relay -is located under the dash? Or under the hood on the driver side? Can anyone make a suggestion? Thanks!
Old Jan 3, 2007 | 12:28 AM
mongoose_Fear93's Avatar
mongoose_Fear93
Electronic Flasher
An electronic flasher operates both turn signals and hazard warning lamps and im not too sure where that is located but if you find that you probley found your problem sry im no help really on this
Old Jan 15, 2007 | 09:04 PM
2000DurngoSLT's Avatar
2000DurngoSLT
the 2000 durango uses a 12v 5 prong flasher to run the turn-signals. The replacement part is about $34 from a dealer or $13 froma part store...
remove the old flasher, which is located under the dash on the drivers side, adjacent to the driver's side door behind the side panel fuse box. then simply plug the new flasher into the slot (top slot). ta-da you are done. That'd run about $60 at the dealer.
Old Jul 5, 2007 | 05:21 PM
2000DurangoSport's Avatar
2000DurangoSport
is the flasher easy to locate? i looked after reading your post but i had no luck finding it....
