99 Neon-Can't figure this out-Help?
Old Feb 1, 2007 | 02:23 AM
106deltadart's Avatar
106deltadart
Default 99 Neon-Can't figure this out-Help?
99 Neon-SOHC-80,000 miles-Automatic Last week the battery light came on for 30 seconds and then went off. Next day it had a rough idle. Changed the plugs and checked the wires and ran perfect for 3 days. Rough idle is back and it's cutting out at all speeds. No CEL. Only problems with the car was 8 months ago it threw a CEL and I scanned it and it was the MAP sensor. Took it out and cleaned and no problems since then. What is confusing me is no CEL is being thrown. Have owned 3 Dodge Spirits and have had to replace 4 O2 sensors over the years. 2 times the bad sensor threw a CEL and the other 2 it didn't. My mechanic said they will do that sometimes. This Neon has the original 02 sensors. Would change the fuel filter but the 99 has the filter/regulator set-up. Is there a way to check that? Would like your input. Many thanks!
Old Feb 3, 2007 | 02:18 AM
blue flame dak's Avatar
blue flame dak
Default RE: 99 Neon-Can't figure this out-Help?
did your car act up when the weather was wet? these engines have problems with the plug wires breaking down when wet. try mixing salt and water in a spray bottle and spray on your wires. let the water soak for a minute or two then start your car and see if it misses.
Old Feb 5, 2007 | 06:26 PM
neoncrazy101's Avatar
neoncrazy101
my Neon does that. So far though it hasn't stalled or anything. check the battery terminals and the grounds to make sure their all connected, they have a tendancy to just randomly come loose a little and such.
