Power Window Regulator
Old Feb 14, 2007 | 06:28 PM
psychodadw's Avatar
psychodadw
Default Power Window Regulator
This is on a 2002 Dakota SLT Quad Cab 4.7L 4wd
Did this plastic piece break off of the Power Window Regulator?
It certainly looks like a cable holder/slide of some type.
I can't get the window to drop down, one of the cables keeps tightening
and binding the window.
I was thinking I can just cut the cable and then the window will come down,
but before I go tearing and ripping I want to make sure.
I can't find a good enough pic ofa regulator.
Their was ice on the window and without thinking, I tried to open the window and just heard a cracking noise.
Then this piece was laying at the bottom of the door.
[IMG]local://upfiles/4319/0BBE26B6A98F4F4F918FB8DFD0E4CE13.jpg[/IMG]
Old Feb 20, 2007 | 11:07 PM
psychodadw's Avatar
psychodadw
Default RE: Power Window Regulator
It was the power window regulator. The cables were bound up tight, I taped the window up in position and I just cut the cableswith bolt cutters. I swapped it out in less than 1/2 an hourincluding all the door panel rods and screws.
It was pretty easy.I bought a new regulator at mylocal Advance Auto for $99.
