A/C Compressor bearing.....
Old Mar 20, 2007 | 01:57 AM
abbotsfordken's Avatar
abbotsfordken
Default A/C Compressor bearing.....
..... my wife's little '95 Neon is a fully optioned 4 dr with the combination Heater and A/C. When the system isactivated with the fan on in either the Heater Defrostor A/C position, and with the clutch engaged, there is a loud bearing squeal, but only under load. At idle............. no noise. While under normal driving conditions and the Heater Defrostor A/C on, the squeal returns. The Heater and A/C works great, just has the squeal. The noises cycles with the on-off of the clutch engagement. I suspect that the compressor bearing is failing and have unplugged it to avoid the noise. My question is then.............. is the bearing itself changeable or does the entire compressor have to be replaced ?? I have the factory service manuals as well as a Haynes manual and there is no mention of my problem or even whether or not the bearing itself can be replaced. Anyones help is appreciated.................
