1998 Dodge ram 5.2L 4x4
Old May 16, 2003 | 11:33 PM
snack's Avatar
snack
Default 1998 Dodge ram 5.2L 4x4
First off hey everyone Im new to the board. Iwas wondering if anyone could give me some insight as to why I have to crank my engine twice before it starts?</P>
Thanks!</P>
Steve</P>
</P>
Old Jun 1, 2004 | 11:10 PM
rambo97's Avatar
rambo97
Default RE: 1998 Dodge ram 5.2L 4x4
hmm, weird! I have a 97 5.2 4x4, which are the very same under the hood and throughout... I had that happen to me for a week straight, I had to crank it a few times to start it, turned out to be my fuel pump ( engine wasnt gettin gas to it! ) but other than checkin the fuel pump which often goes on our year rams, I have no idea, post when you have figured it out though, Im interested in case it ever happens to me!
Old Jun 1, 2004 | 11:45 PM
JCswm's Avatar
JCswm
You need to check your fuel pressure during cold cranking. you probably need a fuel pump
TSB# 18-35-97 is a PCM flash that makes it run better cold
Old Jun 2, 2004 | 04:10 AM
dodgemech's Avatar
dodgemech
You could go that route or try a regulator assy, much cheaper and easier to chage.
Old Jun 3, 2004 | 03:00 PM
uawnick's Avatar
uawnick
Replacing the regulator is only a bandaid In my opinion.. Just go straight to the source and fix the core problem... If not, down the road you will wish you had
Old Jun 4, 2004 | 04:35 AM
dodgemech's Avatar
dodgemech
The regulator is usually what fails-it is also the fuel filter(shhh don't tell, most people dont know).
