Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
What would cause a jeep to shake and backfire when you start the jeep?
Old Jan 31, 2012 | 12:21 PM
terenkleon's Avatar
terenkleon
Default What's the online casino with the best player loyalty program?
When I play at Harrah's casino, they give me cash back for my slot machine and video poker play. Do online casinos offer similar loyalty programs?
Old Feb 1, 2012 | 11:55 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
Could have a misfire or a bad crank sensor, thats causing a misfire. Also could a bad coil pack rail too.
Old May 17, 2012 | 06:11 AM
gregert12's Avatar
gregert12
change the plugs
Old Jul 26, 2012 | 05:04 PM
vaninator's Avatar
vaninator
try ignition coil thats what it was on my 93 grand Cherokee
Posted from Dodgeforum.com App for Android
Old Aug 30, 2012 | 04:01 PM
Countryboy_4_life's Avatar
Countryboy_4_life
As already stated it does sound very much like a misfire which alot of times is due to the spark plugs.
Another thing,does it do it after being restarted after a short period of sitting particularly on a warm day? That's a common problem with those year XJs, My 2000 Cherokee did that a few times. Something with heat being trapped around the number 4 or 3 injector and the fuel vaporizing, causing it to misfire if it was started up before the heat dissipated. Does your parents Jeep throw a Check Engine Light? Mine would, would show that it had a random misfire code.
Old Sep 1, 2012 | 03:58 PM
moe7404's Avatar
moe7404
i have found on chrysler engines with a distributor gets moisture in the cap. .distributor moisture fix. Some chrysler distributor cap that has an air vent, needs to have the vent plugged. Best to use JB-weld. But there might be some brands that run air through as part of the system, dont seal them
Old Sep 3, 2012 | 08:42 AM
Countryboy_4_life
2001 Cherokee doesn't have a distributor cap
