JeepsThe tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
if you truly have a converter from a 44 RE and a 46 RE trans or vise versa... NO GO. the 44 series is based off the 904, the 46 based off the 727/ the splines are smaller diameter on the 44 than the 46.
It turned out that TC was obviously from some older model of 46RE/A518 as it was all OK except of that one offset bolt which I resolved by grinding the hole oval.. As for later shifting problem, it was the governor pressure sensor/solenoid, I changed them both and the problem gone. Thanks everyone!
