Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
Small Jeep Patriot Comparison
Old Sep 3, 2006 | 04:55 AM
RevToTheRedline's Avatar
RevToTheRedline
Default Small Jeep Patriot Comparison
Here is a little comparson I made between other vehicles within the Patriots price range.
2007 Jeep Patriot Sport Freedom Drive II
Drivetrain Type: Full-Time 4x4, Lockable Center Coupling, Low Range, Off-Road Brake Traction Control, Hill Decent Assist, Open Differentials, 3 Mode ESP
Ground Clearance: 9"
Approach Angle: 29
Departure Angle: 33
Breakover Angle: 23
Engine: 2.4L I-4, DOHC, Dual VVT, 172hp, 165ft-lbs
Transmission: 2nd Generation CVT w/ Low Range
Low Range: Yes
Suspension: 4 Wheel Independent
Tires: 215/65-17
2007 Honda Element EX AWD
Drivetrain Type: Honda Real-Time 4WD: FWD w/ AWD assist when front wheels slip, upto 20% torque to the rear wheels (Mechanical system, uncontrollable), Open Differentials
Ground Clearance: 6.9"
Approach Angle: 23.9
Departure Angle: 21.3
Breakover Angle: Unkonwn
Engine: 2.4L I-4, DOHC, VTEC, 166hp, 161ft-lbs
Transmission: 5 Speed Manual or 5 Speed Automatic
Low Range: No
Tires: 215/70-16
2006 Suzuki Grand Vitara X-Sport 4WD
Drivetrain Type: Full Time 4-Mode 4WD, Low Range, Limited Slip Center Coupling, Open Differentials
Ground Clearance: 7.9"
Approach Angle: 29
Departure Angle: 27
Engine: 2.7L V6, DOHC,185hp, 184ft-lbs
Low Range: Yes
Tires: 225/70-16
2007 Toyota RAV4 Sport 4WD
Drivetrain Type: Electronic On-Demand 4WD, Hill Start Assist, Hill Decent Assist, Traction Control, Limited Slip
Ground Clearance: 7.5"
Approach Angle: 29
Departure Angle: 25
Engine: 2.4L I-4, VVT, DOHC, 166hp, 165ft-lbs or 3.5L V6, VVT, DOHC 269hp, 246ft-lbs
Transmission: 4 Speed Automatic (I-4) or 5 Speed Automatic (V6)
Low Range: No
Tires: 235/55-18
2006 Kia Sportage 4WD
Drivetrain Type: Electronic On-Demand 4WD, Open Differentials
Ground Clearance: 7.7"
Approach Angle: 29
Departure Angle: 28
Engine: 2.0L I-4, CVVT, DOHC, 140hp, 136ft-lbs or 2.7L V6, DOHC 173hp, 178ft-lbs
Transmission: 5 Speed Manual or 4 Speed Automatic (I-4) or 4 Speed Automatic (V6)
Low Range: No
Tires: 235/60-16
2005 Land Rover Freelander
Drivetrain Type: Full-Time AWD, Decent Control, Traction Control, Open Differentials
Ground Clearance: 7.3"
Approach Angle: 30
Departure Angle: 34
Engine: 2.5L V6, DOHC, 174hp, 177ft-lbs
Transmission: 5 Speed Shiftable Automatic
Low Range: No
Tires: 225/55-17
2007 Toyota Tacoma Regular Cab 4x4 (This is a truck which I shouln't have really included in the comparo)
Drivetrain Type: RWD, Part-Time 4x4, 2 Speed Transfer Case, Open Rear Differential, Automatic Locking Front Hubs
Ground Clearance: 9.4"
Approach Angle: 35
Departure Angle: 26
Breakover Angle: 27
Engine: 2.7L I-4, VVT, DOHC, 159hp, 180ft-lbs
Low Range: Yes
Suspension: Independent Front Suspension (IFS) w/ Solid Rear Axel
Tires: 245/75-16
2007 Ford Escape XLS 4WD
Drivetrain Type: Full-Time AWD, Open Differentials
Ground Clearance: 8.2"
Approach Angle: 20.8
Departure Angle: 28.1
Breakover Angle: 20.8
Engine: Duratec 2.3L I-4, 153hp, 152ft-lbs
Low Range: No
Tires: 225/75-15
Old Sep 3, 2006 | 09:01 PM
neoncrazy101's Avatar
neoncrazy101
Default RE: Small Jeep Patriot Comparison
the Landrover doesn't have low range? now thats just sad lol
