Jeeps The tough off road capability of ANY Jeep model from the Wrangler to the fully loaded Grand Cherokee keeps this cousin of Dodge the king of every hill.
96 Grand Cherokee Tranny Issue
Old Dec 27, 2006 | 03:01 PM
mad gsr's Avatar
mad gsr
Default 96 Grand Cherokee Tranny Issue
I have a 96 Jeep GC Limited 5.2. Recently it threw codes p1762 and p1763 which are the TCM codes. The dealership wants $150 to hook up the computer and test just to see if it is bad. My problem is no 1st or 2nd in Drive. I have 2nd in the 2nd gear spot and then i can shift to d for 3rd, and on. Btw how many gears does the tranny have 4? or 5? I dropped the pan replaced the filter and fluid which was also done about 23,000 miles ago. everything looked good no debree in fluid because someone said 1st is a disc pack and you might see the clutch particles. Problem is when it does go into 1st that it won't shift out, it gets stuck and i have to turn it off and when i usually recranck it it will go back to 2nd and so on. I'm sure i'm not the only one with this problem so i figured i'd give it a shoot and post on it. I have to get this done because the emissions place won't pass me because of this and i have heard lots of theories of i could be debree, or the tcm, the disc, and even the tps. Thanks
Old Jan 12, 2007 | 07:39 PM
mad gsr's Avatar
mad gsr
Default RE: 96 Grand Cherokee Tranny Issue
found out what it was.
