K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
drivetrain questions
Old Sep 3, 2007 | 10:46 PM
TwoPointFivePar's Avatar
TwoPointFivePar
Default drivetrain questions
I own a '94 sundance with a 2.5 and 5 speed tranny, I've noticed that when launching the right tire will spin for a brief moment and then the left tire will start to spin too. does this mean my car has a limited slip differential? I believe that one ofthe previous owners did some kind of work to the clutch/differential, the clutch is extremely stiff and takes quite a bit of effort to press down. Also when I got the car all the plastic in the driver's side wheel well was missing. I was wondering if it ispossible a previous owner put in a heavy duty clutch/LSD?
Old Sep 4, 2007 | 08:02 AM
speedyshelby's Avatar
speedyshelby
Default RE: drivetrain questions
I doubt it since the cheapest one out there around 300 and it won't last long. The very good one for these cars around a 1000. The reason one will spin on the passenger side there no wieght over there but once it gets heated from spinning it grabs then other one looses traction.
Old Sep 4, 2007 | 11:52 AM
TwoPointFivePar
really? I think the clutch has been upgraded at least because it has 140,000+ miles on the odometer and the clutch is still really solid and stiff.
Old Sep 4, 2007 | 09:58 PM
speedyshelby
The clucth doesn't anything to do with diff. Not saying it doesn't have a good clucth. LSD would cause both to spin or both not to at the same time.
Old Sep 8, 2007 | 01:41 AM
TwoPointFivePar
I know at first I asked if you thought it would be possible if someone put a heavy duty clutch in it also. and yes both wheels spin at the same time...
I check everyday just to be safe.
