K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
MPFI 2.2 NA?
Old Sep 30, 2007 | 12:00 PM
1994shadowman's Avatar
1994shadowman
Default MPFI 2.2 NA?
So I know they made them in Mexico. But I plan on making my own. A friend has a 2.2 Turbo intake and TB. I plan on making the Shadow MPFI. Firs of all could it even work? And if it can, What I need to know is do I need the turbo computer to fire all injectors? Or is there a way to change my wiring to set it up to fire all 4 injectors without changing the computer.
Old Sep 30, 2007 | 05:00 PM
speedyshelby's Avatar
speedyshelby
Default RE: MPFI 2.2 NA?
Look in the yards they made them in the USA to it was the flex fuel verison that got lots of goodies. Plastic gas tank, stainless lines, stailess fuel rail, stainless fpr, and bigger injectors then the turbo cars got but they had the fuel pressure turn down on them.
You can run the engine without the turbo computer you just have to batch fire the injector all at once not the best thing to do but it will run. Go to turbododge.com and look into the N/A section.
Old Nov 8, 2007 | 01:03 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
You'll need to swap the computer and wiring harness, as obviously the TBI harness will not have injector connectors and TBI fires injectors every half revolution, MPFI batch fires 1 & 3 on one rev, 2 & 4 on the other. Not sure about the distributor compatibility. I also can't tell you for sure that the turbo manifold will bolt up to the N/A head; They're not the same engine.
Old Nov 8, 2007 | 10:25 PM
speedyshelby
Turbo manfold will bolt up. The head are the same except for the exhaust valve and the taper shroud. The whole motor is pretty much the same except for the rods, pistons, and manifolds.
Old Nov 9, 2007 | 12:50 AM
Sixtysixdeuce
That, and the block casting. The NA 2.2 is missing some tapped bosses for things like the intermediate shaft bearing bracket.
However, Napa does not specify Turbo or NA on the only gasket they show for 2.2.
Old Nov 9, 2007 | 07:50 AM
speedyshelby
You don't need that bearing bracket if you run the unequal shafts. Turbo automatic cars didn't get the bracket either.
Some build up a n/a block for there turbo cars. I currently got a n/a cam in my turbo engine since they got a better profile.
