K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
need help from the shadow experts
Old Jan 13, 2008 | 03:52 PM
TwoPointFivePar's Avatar
TwoPointFivePar
Default need help from the shadow experts
I need to know where the ground for the heater on my 94 shadow is, Ive checked the heater motor and it blows fine when you jump a wire from negative to ground. the heater currently won't blow and the radio also stopped working when the heater did. according to wiring diagrams the ground looks like its under all the plastic **** on the passenger side footwell. is this where it is?
sorry for the run on sentences and any other grammar mistakes but it's cold as hell(well not really hell) but you get what im saying when i have to drive to work. any help would be appreciated
Old Jan 15, 2008 | 12:06 PM
CSX173's Avatar
CSX173
Default RE: need help from the shadow experts
I do believe there is a ground splice under the carpet on the pass. side. Also, if you haven't checked them, sometimes the resistors to control the fan speeds can all burn up from water getting to them. Then, the heater won't work at all either. Good luck and stay warm......
Old Jan 15, 2008 | 03:03 PM
TwoPointFivePar
I've changed out the control because i thought that was the problem first(5 bucks from a junkyard) because the car did have a windsheild leak..... the ground should be under the carpet?
Old Jan 17, 2008 | 03:18 PM
TwoPointFivePar
alright, found the ground, cleaned the connections, still no work
so, since the ends looked pretty corroded I cut them off and replaced them
still doesnt work.
Im only getting about .3 volts through it so I'm pretty sure it is the heater motor resistor... anybody know where i can find this thing? ive been lookin for about 2 hours now
and im starting to forget the idea that dodge engineers always made their cars easy to work on.
Old Jan 28, 2008 | 12:17 PM
CSX173's Avatar
CSX173
I haven't had to work on my Shadows for a long time in that area. (Good thing). I will have to go home and look in the FSM. If you need it quicker, look online.I hear the manuals are out there somewhere.
