K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
Empty gas tank with fuel pump?
Old Mar 22, 2011 | 10:51 PM
fixxer62's Avatar
fixxer62
Question Empty gas tank with fuel pump?
Anyone know how to empty the fuel tank using the fuel pump on a 93 Dodge Dynasty. I'm sure there is a way to jumper the wires somewhere and pump the fuel out of the fuel rail bleeder valve. I just don't know which wires to jump. This car has been sitting for over 3 years and I need to drain the tank.
Old Mar 23, 2011 | 06:35 AM
22DODGE22's Avatar
22DODGE22
It's really easy. You're better off disconnecting the fuel line from the rail. Going thru the schroeder valve will take forever.
Now find the fuel pump relay, just take a paper clip and jumper 2 wires
Old Mar 24, 2011 | 08:00 PM
fixxer62's Avatar
fixxer62
Default Thanks but where is the relay?
Thanks for the reply. What I did to check the fuel pump was take the stem out of the schrader valve, and gas squirted out of it really well, and so I attached a hose to it. But I don't know where the relay would be.
Old Mar 24, 2011 | 09:37 PM
22DODGE22's Avatar
22DODGE22
Takes like 10x longer to get the fuel out thru the little schrader valve. The relay is under the hood, get out the owners manual and have a look or a shop manaul or feel them as teh key gets turned on, it will click on then off.
