K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
1986 Dodge 600 SE
Old Oct 4, 2011 | 12:05 PM
tbellomy's Avatar
tbellomy
Default 1986 Dodge 600 SE
HI I have an 86 Dodge 600 SE Turbo engine. when i put the car into Drive, i have very little play with the pedal. if i force it down, it will pop into neutral. I haven't done any work on it, it just happened suddenly.
Any ideas would be helpful"
Old Oct 4, 2011 | 08:53 PM
rare aries's Avatar
rare aries
Keeper of the Ks
It sounds like you may have two things going on, first is a sticky throttle cable, easy fix get some WD40 stick the straw inside the cable jacket and spray work the throttle till it frees up second your shifter linkage may have to be adjusted sounds like its not fully engaging into gear.
