K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
change the timing
Old Aug 17, 2005 | 11:40 PM
SloShadow90's Avatar
SloShadow90
Default change the timing
how do u change the timing, and what should it be set to? thanks for the help guys
Old Aug 18, 2005 | 03:02 AM
Bassboy's Avatar
Bassboy
Default RE: change the timing
Go pick up a Haynes manual from your local auto parts store it will run you about 17 bucks and explain how to set the timing. There are a few websites out there that also explain it but this is the easiest way; plus then you have the book that will help you with other problems
Old Aug 19, 2005 | 02:41 AM
SloShadow90
thanks man, so if i change the timing back to the stock settings if its off, should this give me more power, the car feels extremely powerless right now!!
