K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
Dodge Aries 1989 Series K Issue
Old Jul 16, 2014 | 09:22 PM
jxplorer's Avatar
jxplorer
Unhappy Dodge Aries 1989 Series K Issue
I have a 1989 Dodge Aries K 4 cylinder 2.5 liter engine with an automatic transmission. When I start the car from a cold position, it idles smoothly. But after approximately 8-10 minutes, the car begins to idle rough and then black smoke comes out from the muffler instead of the normal gray smoke.
Hoping to address the root cause of the problem, I have installed the following parts: a new throttle body, a new EGR valve, a new distributor shaft and cap, a MAP sensor, a new coolant sensor, new spark plug wires, four new spark plugs, a new ignition coil and a new air cleaner filter. Nothing seems to work!
Does anyone have any idea what's causing this?
Old Jul 17, 2014 | 10:28 AM
Disconnect the O2 sensor before the cat. It will set a code, but, my guess is, the problem will go away. If it does, replace the sensor.
Old Jul 18, 2014 | 09:17 AM
jxplorer's Avatar
jxplorer
Default Dodge Aries 1989 Series K Issue
Thanks Hey You!
I'll give it a try.
