K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
check engine light on
Old Oct 26, 2003 | 11:15 PM
kassab's Avatar
kassab
Default check engine light on
hi</P>
i have dodge spirit 89 auto,4 cyl 2.5 l..</P>
last time i fixed the timing belt,now when i drive the light check engine is on and the oil light is onand on till i turn the ignition off and start again.i check the oil it is max..no need for oil. what is wrong?</P>
thank you</P>
Old Oct 27, 2003 | 03:39 AM
71RoadRunner's Avatar
71RoadRunner
If you haven't already try disconnecting the battery negative cable for 5min. and then reconnect it and see if the check engine light is still on. If it is still on check the computer to see what is wrong. If you do not know how to check it see my post in Intrepid,Neon&Stratus forum under My Neon is sick...Help? I tell how to check the computer.
Old Oct 27, 2003 | 11:11 AM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
Here is a quick link to that topic:
https://dodgeforum.com/forum_posts.asp?TID=439&amp;PN=1
~Amanda
Old Oct 29, 2003 | 06:38 AM
71RoadRunner
Now why didn't I think to do that?LOL It would have been a lot easier puting a link in it.<edited><editID>71ROADRUNNER</editID><editDate>37923.1525694444</editDate></edited>
Old Oct 30, 2003 | 10:28 AM
ViperGTS's Avatar
ViperGTS
LOL. I guess i was too late to answer the question
Old Dec 15, 2003 | 08:47 PM
GTCandGTSturbo's Avatar
GTCandGTSturbo
You think it could have something to do with that apparent headgasket problem? Either that or your engine has some serious internal wear in the bearings that is not allowing you to have enough oil pressure. Thats worst case senario of course
Old Jan 28, 2004 | 02:27 AM
caravansasleepr's Avatar
caravansasleepr
you can pull your codes via you ignition key to see what the problem is . To do this you must turn ignition on , off , on ,off, and then on your codes will start to flash before your eyes all Chryslers after 1984 have this feature no need to see the local rapist <IMG src=smileys/smiley7.gif border="0"> Caravansasleepr
Old Jan 28, 2004 | 04:14 AM
71RoadRunner
The 2nd and 3rd posts already took care of that. <img border="0" src=smileys/smiley2.gif border="0"> <img border="0" src=smileys/smiley36.gif border="0">
