K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
N/A 2.2 vibration...help
Old Nov 1, 2019 | 05:06 PM
3rdelke's Avatar
3rdelke
Default N/A 2.2 vibration...help
Bought a 82 rampage, 5220 holley. No computer or o2 sensor. Changed 3 motor mounts. Rebuilt 2 different carbs, nothing helps this vibration from idle to top speed on the highway.
Help
Old Nov 2, 2019 | 10:11 AM
Moparite's Avatar
Moparite
The early 2.2 didn't have balancer shafts like the later ones did. If you are sure it's the motor causing it (not a miss fire/weak cylinder etc) may want to upgrade to the later versions of the 2.2/2.5's Or consider a V8 swap!
https://bangshift.com/general-news/c...-power-inside/
Old Nov 13, 2019 | 05:50 PM
Viperdave's Avatar
Viperdave
The only 2.2 that had balance shafts I think were the 2.2 vnt engines, all others were 2.5 4cylinders which weren’t available in 1982
engine vibrations can come from a miss adjusted timing belt but you would also have sluggish power and distributor would be cocked around and not lined up properly
