Alignment help - 88 Aries
Hi,
What's the maximum amount of negative camber you can get on the front of these with the stock setup - struts / eccentrics etc ?
It seems like you can get a STACK more positive camber than you can negative.
Is there any alignment (toe / camber) adjustment for the rear ?
Also, does anyone have the stock specs, and any detailed instructions on adjusting it ? The Haynes manual doesn't give any information, except for what you can bck out from the general suspension dissassembly stuff.
Thanks,
Mike.
Thanks,
Mike.
