K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
lancer specs
Old Jul 13, 2006 | 01:54 AM
Aarons89lancer's Avatar
Aarons89lancer
Default lancer specs
it is a 2.2 turbo 2 i had to replace the 555 tranny with a 520 so that i can rebuild the tranny cause the 3rd and 4rth shift fork broke and i cant find one. i would like to know what turbo,intercooler to run and will srt 4 injecters and fuel pump work in the car
Old Jul 13, 2006 | 01:34 PM
speedyshelby's Avatar
speedyshelby
Default RE: lancer specs
srt 4 injector won't work since they are high indepence and your lancer uses low indepence injectors. If you try it anyways you get an injector code and later down the road you fry the computer. As for the pump why use the srt-4 pump I don't think it will work if you want a bigger pump run a walbaro and for injectors you can use dsm 1 gen.
here an other fourm that talk about using dsm injectors.
http://www.turbododge.com/forums/sho...d.php?t=119059
