K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
89 Omni wont start???
Old Jul 28, 2006 | 01:22 AM
Sublime69's Avatar
Sublime69
Default 89 Omni wont start???
I have an 89 omni and its been sitting for a couple months. It started up two days ago but today i went to start it and it just cranked. I found that it has no spark from the coil. So i replaced the coil and still nothing.. and one have any suggestions? could it be a bad ecm?
Thanks
Old Jul 28, 2006 | 04:31 AM
speedyshelby's Avatar
speedyshelby
Default RE: 89 Omni wont start???
Check the codes.
http://minimopar.knizefamily.net/fault/index.html
My best guess would be the hep under the distriber cap. If it goes bad then it can't tell when to make the spark.
Old Jul 28, 2006 | 11:38 AM
Sublime69's Avatar
Sublime69
...but the coil wire isnt even sparking=
Old Jul 28, 2006 | 07:23 PM
speedyshelby
The hep is what tell the coil to spark if the hep ain't work there be no spark. If you run the codes it should tell if it bad. Other than that it could asd relay.
Old Jul 28, 2006 | 08:04 PM
Sublime69's Avatar
Sublime69
what does hep stand for, just need to know when i try to ask for it at the parts store
Old Jul 28, 2006 | 08:54 PM
speedyshelby
hall effect pickup sensor.
Old Jul 29, 2006 | 02:04 AM
rareram's Avatar
rareram
Could even be a broken timing belt.
Old Jul 29, 2006 | 08:24 PM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: speedyshelby
Agreed...the pickup plate is a common problem with no spark on the Omnis
Old Aug 18, 2006 | 06:39 AM
ultimateanswer's Avatar
ultimateanswer
Depending on how many miles you have on you car and when the last time it got a really good tune up it may be time for a new timing belt and ignition system. On my Omni when I got it it had been owned by a very ignorant old woman for its entire life and she had never done any matenince on it besides the mandatory oil every 3 month(yes every 3 monthes not 3k mi). The first thing that went wrong was the ignition system, then shortly there after the timing belt snaped like an overstressed rubber band. It wasn't a bad bill but it was still more that what prevntive matenince would have cought. But by far the most difficult thing you will have to do is convince the wife that you really NEED to spend 400-600 dollars on a 20 year old car.
