K-Cars The generation of cars that will forever live in infamy. The glorious K-car.
trouble
Old Jan 2, 2007 | 08:42 PM
jmja9281's Avatar
jmja9281
Default trouble
Hey guys I was swapping out my starter when a bolt fell into the tranny converter housing. My question is do you guys think that the bolt possibly fell to the oil pan or maybe to the differential pan. I have a 3 speed tranny thanks for your time and the feed back
[IMG]local://upfiles/32039/3A7B200A767D44C4AD96DB39D676A94C.jpg[/IMG]
[IMG]local://upfiles/32039/23235C5CDFC64C5692E0DD70A267381D.jpg[/IMG]
Old Jan 2, 2007 | 10:34 PM
speedyshelby's Avatar
speedyshelby
Default RE: trouble
Take the lower inspection shield off and you may be able to fish it out.You can't get a bolt into the oil pan or the different pan since those are sealed. I would get that bolt out since it could catch on the conveter and do some damage. The lower inspection cover comes out but removeing the lower bolts to the housing. You have to loosen some bolts on the front motor mount and also take off the suport bracket on the rear. Then there should be one 10mm bolt dead center of the cover.
Old Jan 2, 2007 | 10:43 PM
jmja9281's Avatar
jmja9281
Default RE: trouble
speedyshelby thanks man for your help. I am not sure where the lower inspection shield is if you have some pics of it of maybe a link that could show me what to look for. thanks
Old Jan 3, 2007 | 01:56 AM
speedyshelby
Default RE: trouble
If you jack up the car. Crawl under it and look between the motor and trans there is a thin tin shield the goes between it. If your lucky if you get the shield out you be able to get the bolt depending on the size of it.
Old Jan 4, 2007 | 12:27 AM
jmja9281's Avatar
jmja9281
Default RE: trouble
Thanks for the tips they are a great help. Thanks speedyshelby.
